Tighten Automatic Shifter in an SV21
McCoy
Hey guys,
There are a few things on my SV21 that need attention, but the first one I notice each and everyday is my shifter.
Its an automatic, so it has the T shaped shifter. It has become loose so i can move it say 2-3cm to the left or right.
I'm also able to manouvre it between R - N - D - 2 without holding the button. It's not a huge issue but it's an issue nevertheless.
What i'm asking is, is there a way I can tighten it from inside the car or will I need to jack it up and start replacing parts?
I'm yet to get quotes from auto service centres, but I first wanted to check if this was something a novice was able to do.
Thanks guys :)
