lowering blocks
Moley
Hi all,
just come back from first long trip in newly purchased hilux 2x4 dual cab 2004. Previous owner fitted lowering blocks (around 75mm high). As a new kid on the block;
  1. does this automatically mean a firmer ride? (bumps in the road come right thru into my buttocks!!)
  2. will removing the blocks raise the tray the whole 75mm ?
  3. will removing the blocks mean I can carry more weight in the tray?
  4. should they stay or should they go?
Any ideas would be apprec.
Geoff
Q1 better handling-no change to ride firmness unless shocks u/s.
Q2 yes
Q3 shoundn't
Q4 personal choice. Do you NEED the ground clearance? NB are they a legal fitment? [Has it passed insection with the mod?]
