2zzge no lift
Head Unit with Apple CarPlay
Did you end up getting a head unit for the Rav4? I'm thinking of purchasing one from eBay for my 2015 Rav4. -
RZN169 Poor fuel economy and low/rough idle at cold start up
Hi all, First time writter. Long term reader. I have a RZN169r 1999 Toyota Hilux 3rzfe Manual 4WD with 425,000KM. Which we have owned from 130,000KM. Since about the 400,000km mark (it had a new/used 138,000km engine only, installed at 385,000KMs) it has been using fuel and idiling rough. I'm getting 100kms less then usual. We would normally get 450-550kms per tank. Now getting 350km-400kms. Our long term mechanic of 20 years retired a few years ago and I have no one in my local area who knows these engines or who I trust. Any sugestions on who I can take my car to? I also have no faith in my local Toyota Dealer. I'm in Sydney NSW. Thank you in advance. -
Any RA 60 owners?
Hi all ,new member here. Just wanted to introduced myself and show off my new to me 1983 Celica 2.0 XT liftback. Got from the original lady owner who had it for 41 years! It's had 2 sets of seat covers on the front seats and when I removed them the seats are like new. I'm over the moon with it. I'm southside of Brisbane if anyone is local...... -
Bluetooth stopped working
My 2008 Toyota landcruiser 200 series head unit's bluetooth has stopped connecting to phones, has this happened to anyone else and if so, how do i fix it? Thanks -
Purchasing 2014 Prado GXL - Requesting Inputs
Hello, Thanks for reading my post. We're in the middle of the process of buying 2014 Prado GXL from a private buyer in Brisbane. It has 107K km on the odometer, we arranged an independent inspection and only noticeable issue came out of the inspection is presence of rust. Inspector said general wear (ageing) and rust to the components consistent with the age and mileage. I've attached some of the images(related to rust) from the inspection, please review and let me know if I should be concerned about any future issues or as the inspector mentioned is the rust presence is expected for a 10-year old Prado. Appreciate your help in advance. Thanks, VM -
3rd Gen (XU50) Kluger new aftermarket radio install
Update, yes it does retain the reversing guide -
Hi there sorry for the late response, The reverse guidelines are on the factory camera itself (the guidelines are turned off on the Pioneer unit as it doubled up over the factory camera lines) and if I remember correctly they still retain the angle prediction. Everything else (excluding DAB) works***. But instead of using DAB I've downloaded RadioApp which has all of the DAB stations on it and is accessible by Android Auto (not sure on Apple CarPlay though) so no biggie. I also used an adapter to retain the original GPS antenna, works flawlessly. *** EDIT *** The info on the instrument cluster may or may not show, depending on what interface you end up using. In my case I've lost the audio and navigation info on the centre screen and fuel economy/vehicle customisation screens from the factory head unit but I'm not fussed by it as there are other ways to access them on a Kluger. I think it's all retained if you use iDatalink Maestro and a compatible head unit (it will be marked as such) but besides that and DAB all other functions are still operable. -
Removing low beam bulb 2014 Camry
Thanks, Mate - i'll give it a go. As you say, $15 is better than replacing a damaged headlight (not to mention the aggravation). -
CHASING MANUAL COROLLA LEVIN 01-06
Hi All, Chasing a original lower kilometre 2001-2006 Corolla Levin in Manual, Prefer White, Silver or Blue and in NSW but send through what you got. Thank you
