Air Conditioning Filter, When Do you replace them?
leasaunce
Our Aussie Camries don't have them. I read http://www.micronair.us/assets/pdfs/118.pdf and then checked my 2003 Camry (pulling the glovebox out). It didn't have any filters there whatsoever.
i looked behind my glovebox aswell, i couldnt find a filter either...
i took the pic below, and there seems to be a section in the middle that resembles a 'filter' (just like in that link you posted), but they just moulded the plastic to look like that for some reason :blink:
so there isnt any way to put a filter in, even if we wanted to <_<
Edited by Terry
As for this problem if u dont want to change it there is an aerosol spray which is called "Air-conditioner De-odouriser/ Disinfectant" You should be able to buy this from your service centre or a repco or AutoBarn???!!!Maybe..... It's very nice its more of and odour neutraliser then a fragrance and it kills any bateria that is present in your Air-con system!!!!! ^_^ ^_^
  • 3 years later...
Same problem here. It doesnt look like we can change it. Maybe whole thing needs to be taken apart.
You have to remove the plastic cartridge that holds it in. Push the two clips on the side to slide it out
I tried to do so but it appears that carriage is not removable. Whole thing is moulded as one piece. I will try Toyota spare parts place and post back.
