Posted (edited)
Hi peoples im trying to decide on the rims for the car im a big fan of the bling going around as I have decided its too costly etc to make hp on this car so Im gonna make it look sic
heres some finalists
Some lightweight wheels i think i will use
Edited by 44gze
none of them even slightly suit a corolla!
Id say 3 & 18's. 1 & 2 are heavy wheels,
With 18's you can keep the same rolling diameter as stock with 225/35 tyres. If you go with 19's you will increase your rolling diameter, lose performance and put your speedo out.
  • 4 weeks later...
Not commenting on the style but I will say that 18" is a must if you want the right look.
However if you are going to be using the car from track days you might want to go with 17's as they are cheaper.
If its just a daily commuter/cruiser then get some 18x7.5's and some 225/35/18 rubber. Drop the ride height and those two modifications alone will make such a change to the look of your car!
the CE28N in 18s will cost you atleast a grand each.
You get what you pay for thou :lol:
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
