camry facelift
shaohaok
Personally I think the current model looks obese ! Looks better in dark colours than light colours.
Needs VVT as well for the V6 !
And the tail lights are huuuge!
And........
Thats true, the six isn't vvt yet, I believe oz will get the same V6 from the RX330 which is 3.3L vvti six, this new six is being rolled out across the toyota range.
Starting from the top (lexus) and working it's way down the range.
  • 4 weeks later...
The Avalon, Avensis, Tarago all have foot park brakes, I can't see why they wouldn't bring it out in the camry...Only reason they might not is because the Camry's are built here, everything else gets sent over from Japan/South Africa etc...
Just my thoughts
Pete
I only know of the Lexus ES300 using the 1MZFE with VVTi
Actually, the Kluger also has the VVTi V6, as does the Lexus RX330.
Oh i'm just referring to the same engine the Camry used as being non VVTi
The Camry sold in JP (same exerior shape as OZ Camry) has VVT i V6 , and I think it's the same engine as LEXUS ES300.
It's just that OZ build Camry still use the same V6 engine as previous mode (more square shape, pre02). It's still powerful esp 5MT!
Toyota Japan doesn't sell a V6 variant?!? I just checked the website, all 2.4L
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
