Coolant Maintenance and Check
campbeam
Interested to know what coolant system maintenance checks other forum members are doing.
I regularly check the coolant level and replace the coolant in the overflow bottle about every 6 months. I have bought ph test strips on eBay but have not used them on a regular basis.
Very interested in having the coolant system as efficient as possible particularly with the hot Summer days coming.
After reading the articles in the attached URLs, I am confident that the coolant is in good condition but planning to do a ph test soon.
https://practicalmotoring.com.au/car-advice/what-is-coolant-antifreeze-and-why-does-you-car-need-it/
https://www.cartechbooks.com/techtips/antifreeze
I do whatever the book tells me to do, ie: every 2 years or 45K kms I will flush & refill with the recommended factory coolant which is the Toyota LLC (red) for either ACV36 or MCV20R Camry in the family 50/50 LLC/distilled water. My 86 gets the premixed Toyota SLLC (blue) which has a VERY long life but have already dumped & filled it new when I added the oem WRX oil warmer/cooler.
      1989 Hilux Low Voltage
      Ae92 genuine low ks 70800
      Code P004B
      Upgrade from 2012 to 2023
    9. 3
      Towbars
    10. 5
