Hello mates,
What power ugrades can we do for the 2nz engine. not massive just enough for me to carry full pack and no issues on highways?
You will be better off upgrading to the Yaris YRS with the 1.5litre 1NZ-FE engine.
Personally for highway driving, I would be looking at upgrading to a Corolla Hatchback rather than the Yaris.
Thanks campbeam. I have a bigger vehicle for highway run or long drives. Just incase I want more power on the Yaris Yr? Don’t want to change vehicle.
just really after things to do and what to do. Love playing around with cars that is the reason why I ask.
Cheers,
I am very much into preventative maintenance and optimization/efficiency preferring to keep my vehicles stock standard.
With that approach, you could look at high flow air filter, iridium spark plugs and high quality low viscosity synthetic oil.
One size does not fit all.
Forced induction is a sure way to gain power. Everything else is hit and miss. How much money do you want to throw at it?
Not that much though. So forced induction is out of the game. :)
i think I will end up with Pod filter and upgrade exhaust sytem
You will not make noticable power(possibly none at all) then. You will just make it louder.
A supercharger or turbo will add about 50% more power.  A standard 1.3 is 63 kW. Standard 1.5 is 81 kW (109 HP) or 150 HP with a turbo/super charger.
If you squeeze a 2ZZ Corolla engine with 180 HP into an Echo you would notice more of a difference.
Other improvements recommended would be strut brace and coil overs and if you're really keen a Scion rear axle and trailing arms.
James
Hello trentneyer23, thank for the info mate.
Hello JBM, thank you for the info. Not into engine swap. For super charge around how much am I looking at spending?
This is a form of forced induction, which you said was out of the question.
Yes I know it is a form of force induction. Just want to know. Comparing against engine swap. :)
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
