2zz q?
ok guys ive put the 2zz in the mrs,i got to the wiring then i came across an odd looking plug,
its located on the sump, wats that for, is it important
he 's a pic
Edited by ralyrt
Oil level indicator. It's the orange oil level light that comes on when you start a Stivo then goes out after a few seconds.(If your lucky :P )
I believe Northy had some problems with this light a couple of months ago...... :P
trace the wires back and see if they go to the ECU, if they do there's a good chance the ECU will go into limp mode with them missing to protect the engine.
With it unplugged, you will see the ORANGE oil light on the dash, which indicates low oil LEVEL...
The red light is for you oil pressure...
Leaving the sensor unplugged won't affect your ECU as far as limp mode goes...
What car is this motor going in???
its in are mr2 spyder
Ummm, in that case, the 1ZZ should have the low oil level sensor aswell... If not, don't worry about it...
But if they do, swap them over and plug it in...
Should work fine...
the 1zz dosent have the sensor in the same position, so the plugs might be diff so you may have to make somthing up loom/plug wise
Remove both of them and compare what they look like inside the sump and the diameter that goes into the sump...
They should be interchangeable...
Like take the one out of the old MR2 Motor and install that into the 2ZZ Motor...
Should be fine...
Might also need to extend the wires on the old loom tho...
      help with clutch
    2. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
