Hi guys
I've noticed a couple of drops of oil coming from the drivers side, in line with the right hand side front wheel.
Hoping it's not the dreaded timing case leak.
Any ideas or has anyone experienced something similar?
Car is an 05 facelift Tivo.
It is possible. Best way to find out is to degrease and pressure wash the engine and monitor the area closely.
The only other things I could think of is that it could be power steering but the best way would be to get underneath and have a look in all honesty. I'd definitely say it's highly likely something to do with the timing case or another part within there causing it if you've never replaced the gasket before unfortunately.
Colour & odour of oil should give you a clue 😉
Or you could do what the Car Wizard does and that's to taste it 🤣
  • Haha 1
  • 2 years later...
Did anyone figure this out, my stivo is doing same thing.
