Screaminrollas RA28 Celica
Screaminrolla
1977 RA28 Celica
Engine/Driveline
1G-GTE (Gen 3)
Custom steampipe manifold
Garrett GT3082R
Custom intake manifold
XF Throttle body
450x300x76 intercooler
3" S/S Exhaust
Microtech LTX12S
Bosch ignition coils
440cc injectors
Gizzmo IBC
Camira radiator
W58 Gearbox
Heavy duty button clutch
RN2x Hilux G series diff 4.3 ratio
Factory clutch type LSD
Custom 3' tailshaft
Paint
Vovlo Safron Gold
Brakes and Suspension
Front-
XT130 Corona struts
XT130Corona Lower control arms
Slotted Peugot 604 discs
LN130 Hilux calipers
Lowered Springs
Koni Sport Shocks
Whiteline 24mm Adjustable Swaybar
GZ10 15/16 master cylinder
Rear-
R31 Skyline discs and calipers
Lowered springs
Monroe shocks
Whiteline 18mm swaybar
Custom adjustable panhard rod
Noltec adjustable upper trailing arms
Wheels
16x7 Remotec Borbets(F)
16x8 Enkei's®
Interior
Retrimed Factory Interior
Range of Speco Gauges
Woodgrain Bits and Pieces
Alpine CD Player
Alpine 6' Splits
V-Net 2ch Amp
Battery Moved to Boot
I want to do a project with that 1G - GTE motor into this
Its a popular conversion in South Africa and would like to do it here some time
Thanks for the comments guys, ill try and make some meets once its back on the road im currentlly in the middle of changing the clutch for about the 5th time :rolleyes:
Ill get some updated pics soon, not that the engine bay is much different now.
Zee it hasnt been to wakefield yet im still sorting out a few things to make it a bit more reliable, i did take the ute out there about a month ago though :D
Its pretty fun to drive, its also pretty good at leaving twin black lines everywhere :P
  • 5 months later...
hi,
sorry to drag up an old post. Beautiful car mate, pretty sure i've seen it around on toymods before, may have even spoken to you about some suspension stuff once or twice. I've also got a GA28 and I've just bought an RN20 hilux diff to fit into it. I was just wondering if you could give me some info on fitting the R31 skyline brakes to it and also what needs to be done to the tailshaft? Do I just need to shorten the existing 2 piece shaft or do I have to go for a 1 piece? How much of an improvement did the upper trailing arms make, and are they road legal?
thanks for your help. you can email me at william@willwal98.isa-geek.org if you like or even msn me on willwal98@hotmail.com would be very much appreciated.
thanks again
will
    2. 13
      300 series turbo issues
    3. 55
      Stout Owners
    4. 13
    5. 8
    6. 55
      Stout Owners
    7. 2
      New Member
    9. 199
      Current Oil Specials
