Wheels rubbing guards & plastic?
xTiGeRx
Just did a normal everyday driving run through putty rd from singleton.
checked the car this morning.... :o :o :o :o
looks like i was driving over knives!!!
there's grooves ALL OVER THE OUTER edge of the rubber...
so bad..that there's bit of rubber litterally hanging off the rubber....
does anyone else have the same problems?
i had myself and 2 passengers and lugguage from the weekend.
checked under the guards..and there's already a hole in the plastic...looks like it's actually rubbing against the front bar mounting screw plate...
Hey Influx,
really? not at all?
hehe...coz i'm thinking of going the coil overs...
oh...but what's the offset of your wheels?
mine are really out...
Chris
Hey Influx,
really? not at all?
Chris
If your offsets are really out then you only have the 2 options of either raising the car a bit or new wheels. If they are rubbing that bad it can be dangerous. I have seen a prelude blow a front tyre through a high speed corner because the car was too low with wrong offsets. The Guard just sliced through the tyre and it was not pretty.
One thing to check is in the past King Springs have had a nasty habbit of settling a lot lower than the claimed drop. Maybe they have settled lower on yours.
I read an interesting article in a magazine (europe) about rolling up the inside of arches for such particular cases. Basically you go to town on the inside of your arch with a blow torch and a hammer and then you use a baseball bat to roll it out and make it smooth again.
Although this kind of work is to be taken very easily at any time and dont go too gun ho other wise you end up with nice big bulges in your arches which dont look cool.
If anyone is interested in the article I can post it for you.?
Do you have a pic of the rolled guard??
Guard rolling isn't visible; it's inside, so you wouldn't really be able to tell the difference from the outside (unless you tapped the guard a little too hard... :lol: )
I'd recommend you look at getting a new set of rims. Firstly, it's not roadworthy, and secondly, even if you don't care about roadworthiness, you are putting yourself in a lot of danger, as you can see for yourself from the tyres... :o
Up to you!
i'm really contemplating on either
A) getting new rims
B) getting coilovers (many more bonuses here)
Around the same price anyways.
What do you guys think?
i'm leaning over to the coilovers.
A) getting new rims
Marcus is gonna hate me for this post ;)
but I'd say get the rims, because if you get coilovers, you'll just raise your ride height again - you may as well go back to your stock springs if you're gonna raise your car again!
true..i will be raising the car...just a little bit more...
but...i'm happy to do that.
i don't mind at all.
plus...i can seriously drop it when i want to for shows.
oh...any1 wanna buy some sportivo 'low' king springs??? :lol: :D
from the look of it, offset 40 with 215/45/17, flaring would fix it. I think the tryes are too thick being 45 profile. The offset sounds ok.
Yeah, 215/45 is heaps different from 205/45 or 215/40.
Offset 40 is right, so the problem is the rubber then...
Specification  Sidewall  Radius  Diameter  Circumference    Revs/km
205/40-17          82mm   298mm     596mm         1872mm        534
205/45-17          92mm   308mm     616mm         1936mm        516
215/40-17          86mm   302mm     604mm         1897mm        527
215/45-17          97mm   313mm     625mm         1964mm        509
Considering you should really be using 205/40/R17 or 215/40/R17, you have thrown the total diameter out by over the legal 15mm (according to Victorian ruling), and your sidewall width has changed by over 15mm - 15mm which would normally clear your guards, but obviously no longer :D
i think it is a suspension problem. have a look at the ozzy hall of fame pictures below. looks like good ride height back then but what is it like today?
http://www.ozzytyres.com.au/images/hall_of.../hof_480_bg.jpg
http://www.ozzytyres.com.au/images/hall_of.../hof_369_bg.jpg
Dude,
I think that could be XTigerX's car in those pics!!!! :huh:
Chris Can you confirm?
