T_Money's Bobsled
T_Money
Hey all,
I have had my car for 2 years now but have only really started modding it in the last year. So far it has received:
Engine
NGK Racing Ignition Leads
NGK Iridium Spark plugs
Simota CAI
Suspension/Brakes
Whiteline Front Sway Bar
Whiteline Rear Sway Bar
Whiteline Front Strut Brace
Whiteline Camber Adjusting Bolts
King Springs Low Front
King Springs Super Low Rear
GreenStuff Pads (Front)
Wheels
Sportivo 16's
Sound
JVC GD7200 Head Unit
Response Precision 6.5" Kevlar Splits Front
Response Precision 6.5" 2-way Kevlar Rear
Response Precision 4x100 watts RMS Digital Amplifier
Alpine S-Type 12' Sub
Alpine (D-class) 250 watt RMS Mono Amp
Still to Come
Koni Adjustable Struts
DBA Slotted Rotors front/rear
sportivo grill
sportivo cat back exhaust
Thunder Extractors
eyelids (have them, just not painted yet)
Potenza Adrenalin rubber
Custom Fiberglass sub box (I need more boot space)
TRD S/C ??? (With any luck by this time next year!)
Here are some pictures
Edited by T_Money
Nice man.
There's a guy here in Canberra who did a turbo job on his 1zz if you are thinking of pursuing that path as well as S/C. From memory he's making the same power as us 2zz boys now, I think...
Yeah just personally I'd go s/c over turbo for practicality reasons. The TRD s/c is a straight bolt on unit :) it just seems to be a lot less hassle than a custom turbo set up. I hear that DuGong is giving the sportivo boys a run for their money in an auto with no auqamist. I figure a manual with aquamist set up for the 5th injector should push 120kws??? or there abouts. I would be happy with that, plenty of low down torque to make daily driving an ease and abit of poke when its necessary. After all it is just a corolla and driveability is more important to me than outright speed :P
Edited by T_Money
where have you mounted the coils seeing how you're using ignition leads?
Hey Rollamods,
Okay to calrify, I probably should not have used the term 'ignition leads' - obviouly the 1zz does not have coils or leads as such but rather a coil in lead set up. I replaced the standard (denso i think?) 'coil in lead' plugs with an aftermarket NGK variant (I'm sure the gains are minimal but I wanted to do it so I did). probably wasnt the best money I ever spent seeing as the auto electrician cost me $350 in labor costs :( But its done now so i tend to forget about it. I'll take some photos of them the next time the engine cover comes off for a clean.
Hope that clears everything up :)
Edited by T_Money
right. Fck that's a lot of labour to install a set of coils
Yeah it was...he did some fancy rewiring but I still think I got ripped. I do the majority of work on my car now to save on lobour cost. Good way to learn. :)
Edited by T_Money
  • 2 years later...
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
    5. 4
      2013 camry for sale
      Rav4 smart key keyless entry
