Service Manuals - Please now refer to the FAQ's
Aurion ZR6
Got them all except NAVIGATION one. That one didn't work, said "file not found".
Wow, what a load of docs, thank you very much. Thousands of pages of good info.
I check it out right now.
I just fix it, should work now :yahoo:
Cheers Drew
Edited by Aurion ZR6
Uploaded an Index.html to use with your pdf's so it is easier to surf the pdf's pages.
Just download and under pack into same folder as your pdf's and double click the index.html to use.
Cheers Drew :yahoo:
thanks mate! downloaded all of them :D
EDIT: just a few of points to note.. the html refers to some missing pdfs that isn't available above
Electrical Wiring Diagram Manual (6.4MB, 507 pages)
Ignition (980KB, 12 pages)
Supplemental Restraint System (SRS) (15.7MB, 489 pages)
Edited by saintly
I would definitely be interested in at least the first of the three...
All FIXED! please check if it work please.
Thanks mate.. all working now :) much appreciated your help and response!
/me thinks this topic deserves to be stick'ied :D
Hi can you tell me where you got these manauls as I am looking for a manual for 2008 Kluger.
Dude, though it's semi-relevant... post it in the correct (Kluger Thread) section and you might get a better response. -> http://au.toyotaownersclub.com/forums/inde...?showtopic=9551
Anyone having any problems opening the POWER STEERING file? I can open all the others without problem. I re-downloaded the POWER STEERING file, even tried it on a difference computer with different Acrobat Reader, still get the error message that it can't open the file.
Thanks.
I see the problem the file I have in corrupted as I cannot see it as well.
I have removed this file till someone can offer a working version of powersteering.pdf
  • 4 weeks later...
Will Winrar the whole collection together once I have the Powersteering.pdf
Just a noticed the file will probably be over 266 megabyte. rar file for downloading? :blink:
Is this to large for everyone to download?
      Rav4 smart key keyless entry
    4. 13
      Starter motor issues
    7. 3
    8. 3
