Karu-dina
Hi Y'all.
I just bought a new ride and she's getting delivered tonight.
Built 2001, 2002 model imported and complied 2007.
It is a Mica Blue ST215W Caldina GT-T, Manual. Has 85k km on it.
Stock except for TRD lowering Springs, TRD Front Bar with Dual Fogs (wide or narrow switchable), TRD Gearknob.
It has Factory HIDS and a Sunroof. It has factory Sat Nav (so if anyone can put me in touch with someone who can get it working in Australia I'd be much obliged.
The complier even put in extra immobiliser/security.
If you don't know what these are, have a read here first: Rundown and here for series 1 info: Autospeed article
Trev
Pics:
  • 4 months later...
  • 6 months later...
Bit of an update.
I just had the 100k km service done (96k km on the clock)
It was because the clutch was slipping. So while the box was open I had all the good stuff done.
Exedy HD organic clutch with NPC uprated cover.
New seals, tensioners, timing belt, red coolant, waterpump, plugs.
Baby is running beautifully again.
  • 6 months later...
      help with clutch
    5. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
    8. 2
    9. 1
