SO Close.......
eggbert - yeah was after the elusive 14.XXX pass as per notrthy's coment.
1zz - it doesnt matter how long you take at the christmas tree. the time starts once you leave the line. in this case I wanted to play catchup I let the other guy go off then i lauched hard and chased him ;)
Blue - This run was up against a Purple XR6 Turbo. :blink: I had another run against a 400kW 300ZX which ran a 12.6......i felt so intimidated :P
Talking about Launching hard. When I launch hard (5000 - 6000) the car tends to refuse to go into 2nd (No - I do not wanna discuss my Gearbox woes :angry: ) Well OK ... sometimes it does go in ... and when it does ... B)
I was just wondering at what rev you were launching at ??
cool, nice time mate, judging by ur 60ft time and mph, 14 second pass should be easy!!!
i ran at WSID last nite in my civic vtir, first run ran a 15.49 with a 2.43 60ft, then my third run i got a 15.137 with a 2.21 60ft time!!
first launch was at 5000 - 2.5 60 ft
second launch was at 6000 - 2.4 60 ft
The key to launching in our car is a slight slip of the clutch...dont dump it. and if need be slip it slightly in the 1-2 change also so you stay in lift ;)
It also helps to smoke the tyres, as my first run was with only road driving temp. the second run I smoked the tyres before the lineup (rubber from the track all over my inner guards and under the car now :o )
it had better be clean b4 friday! :angry:
Hey,
We do 14.8 in total stockers, so you need a lot of practice, considering the number of your mods  :P
Try launching from 7k and flatshifting for beginning ;)
our stockers can grab 15.4 - 15.8 so the margin from there to 15.0 is quite a fair bit when you think about it imek ;) :P
1zz - i dont flat shift ;)
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
      High mileage camry
