Project 5S-GTE
Hey Mick, what sump are you running, the 5SFE or 3SGTE one? If you are running the 5S sump where did u tap the oil return? if you have a pic that'd be great
3SGTE sump man, bots straight on
  • Replies 372
  • Created
  • Last Reply
Top Posters In This Topic
i grabbed a spare 5sfe one, as i already have the fitting for it
i can take a pic of where the barb is on mine if you want.. the sumps are identical aside from the barb...
Looks like project 5S-GTE is a GO!
Got this sucker;
bit dirty, but looks to be in good nick
cam covers.. though the 2000 isnt exactly right...
Toyota Variable Induction System!!!!
got motors?
3S-GTE, 4A-GE, 3S-GE (head only)
3S-GTE sump (for trent...)
random corolla parts?
another view... f*ck I have too much sh*t.
talking about pick a part....
can you do like lego with the engines?
This head, that bottom end .... that rocker cover .... :lol: :lol: :lol: :lol:
:P :P :P :P :P
starting to pull it all apart
manifold and butterflies off
manifold off
tvis butterflies
cleaning the manifold
cleaning the butterflies
the head again
all clean
somewhat cleaner head
citra-force is the sh*t
Damn. You cleaned those up nicely.
just a quick scrub in the parts washer did nicely... just wanted to get the bulk of the grease off... will do them properly later.
So here is a quick run down of what i need;
items in bold i have
1 x complete 3sge head (1986) (complete with cams, cam gears, valves, lifters, the lot!, oil switch, rocker covers everything you can score from it)
1 x 3sge timing belt covers (should be 3 covers in total, 3 meaning 2 outside covers and 1 backing plate)
1 x 3sge timing belt and tensioner (with spring)
1 x brand new set of head bolts
1 x 3sge water outlet (go to wreckers) with all the pipe fittings from the 3sge water outlet still attatched cause some different pipe shapes will be required. Try and score the hose clamps too, can never have too many.
1 x VDO adapter to adapt smallest 5sfe coolant temp sender into one of the 3sge coolant sensor mounts on the 3sge water outlet (you will know which of the many mounts to adapt it to when you get to this stage) - might not need this
1 x 3sge intake manifold (including the tvis butterflies, again score as much of the parts off it as you can)
1 x 3sge complete throttle body (from wreckers) (with no electronic ISC valve. You will see underneith, its got no wire plugs for an ISC, only for a throttle position sensor. Pretty sure you will only find this type on the early st162's rather than the late. Say 86' model)
1 x Your current running and healthy 5sfe (healthy block more importantly, if the top end is sick, it will be disposed of anyways)
1 x 1990 GT4 (or alltrac for the U.S) distributor. The 1990 3sge distributor might be suitable, but i wouldn't know, Australia didn't get 3sge powered st184's (Make sure the dissy matches ur stock 5sfe setup, ie: with or without inbuild coil/ignitor)
1 x 3sge ignition leads
1 x 3sge alternator mount, tensioner and alternator belt.
more goodies arrived today :D
Total spend on Stage II thus far;
3SGE Head, Intake, Throttle Body, T-VIS setup, fuel rail, water outlet, etc - $88.00
5SFE Full Gasket Set - $87.50
GT4 Distributor - $0.00 (had a spare one at home)
Total: $175.50
