OIL
kcorro
Nice work Marcus!!! Must have taken you a while to upload with descriptions.
Excellent work.
oh, yeah...stands would be good too. hehe.
You might want to add to insert Axel stands once the jack is up, I've seen the result of not doing this and it is not pretty...
YOU WILL DIE IF THE CAR DROPS ON THE JACK!!!
Better still use car ramps.
Drive on/ Reverse Off.
1ZZ-FE Oil capacity is 3.7 Litres (when you change the filter)
No idea about 2ZZ-GE.
Well done Orrock !
  • 3 months later...
Well done Orrock !
lol sounds pretty simple but the car NEEDS to be level before re filling the oil thats a MUST DO
so reversing off the ramps with no oil doesntreally sound like a good idea
but YES im sure you could give it a nudge and just roll it off :)
Well done Orrock !
2ZZ-GE Oil capacity is 4.4 Litres (when you change the filter).
Questions, what viscosity do people recommend for the 2ZZ-GE stivo engine.
In the owners manuel it recommends API Grade SJ, SL or ILSAC but which viscosity is recommened? 5W-30, 10W-30 or 15W-40?
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
      High mileage camry
