My Clutch/Flywheel installation
so Zee the toms fly is 3.8kg right making it one of the lightest so far
have you had any troubles with it, people say its too light for everyday driving
also
with the exedy clutch
why exedy i never herd of this brand before
why not TRD clutch or toms clutch( if toms have a clutch)
what makes exedy better than those
cheers guys i posted this in a current topic but no response so thought i might bump and older one back to life
The Fidanza is the lightest at 3.4kg. As to driveability i noticed its better than stock. Some say when going up steep hills bcuz of our little torque you can lose speed or need to step on it more but i don't have that problem at all.
Exedy is a the most common and reputable brand when you talk clutches. Daikin makes Exedy clutches and most OEM clutches. TRD also uses their clutches but modifies it to their specs hence more expensive than say a Exedy HD clutch. You won't go wrong with Exedy. I also won't recommend you skimping on clutches, its something vital for the function of your car's mechanicals.
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
So to buy your clutch and flywheel and installation was 385$ is that right??
I mean if thats the case ill go and buy one next week and have it installed i just want to know what the actual total price was for it all???
you are looking at around $350 for labour, $550 for a flywheel and bout $350-400 for the clutch so thats bout $1300 all up. on a side note the HD Exceedy clutch kit has a higher clamp pressure then the TRD one its only by 50kg's or so.
hmm ok sweet
will do a bit of shopping to see who can get me the clutch and fly in my area
would anyone recomemnd the fidenza fly over the toms souly for the lighter 400grams or is it like heaps more expensive and not reall worth it
cheers guys
yeah for sure thanks man thats much better than the 500 mark somone mentioned earlier haha
ive been speaking to zee
ill message screamin rolla as hes a bit closer so i can maybe get to a closer store
you can get a high clamp pressure plate that doesn't exert more force on the fork or pedal. It all depends on the fulcrum point for the fingers. That is why a lot of "heavy duty" aftermarket clutches have a lighter pedal feel than a stock clutch.
oh really haha
but our clutches are already TOO light for my liking
i as hoping the heavy duty clutch might actually put a little bit of weight behind it
You not driving your ute Justin!! :P Try out Honda's cluthes (eg. Type S), they are sooper light! I noticed with the ExedyHD kit it did feel abt the same as stock, and the pedal pressure is consistent throughout the pedal stroke.
i'm not very good with cars but i do want to get rid of my 1-2 shifting problems.
i hear ppl say that buying a flywheel and clutch will solve the problem.
i'll be ordering the following parts from a TRD distributor in hong kong:
clutch cover
clutch disc
flywheel and bolts
is that all the parts i need?
thanx
clutch cover
clutch disc
flywheel and bolts
thanx
Go to Toyota and get them to do recall on adjusting the slave cylinder push rod on the clutch. Solves the shifting problem straight away.
yup
u might want to change your throwout bearing whilst u're at it. not really essential but onoe of those things u might as well do.
and while the gearbox is removed to put the clutch and Flywheel in, may as well open it up and chuck an LSD in there
yup
and while the gearbox is open check your gears and synchros, if they are worn chuck in some super close ratio gears :P
Edited by ZEEROLLA
haha if money wasn't a problem
but i am still thinking about getting an LSD
yup
actually that might be a top idea
put the LSD in whilst everything else is out fo the way
how much is it for an LSD
i know just the store to go to for this but rough prices will be appreciated
cheers
hmm
i was gonna keep it stock 5months ago hehe but now its turning into a street machine LOL
if i get it overseas its approx $900 with current currency exchange rates. this is for the TRD one.
could be other alternatives and cheaper too. but i haven't really done any research into this. in other words i'm clueless :P
    2. 4
      Head Unit with Apple CarPlay
    3. 8
      1kzte throttle body
    8. 3
    9. 5
    10. 5
