Hey Guys
I'm having trouble with one of the doors sills ( Rear Right) as it doesnt turn off if the Both front door is open.
Any ideas guys ?
it cost me about 100bux inc postage
Thanks.
hey can i ask where did you get them from, i might be interested for mine!!!
Hey Guys
Any ideas guys ?
Thanks.
hey mate,
the door sills when wired up will only be on when A door is open, if the front door/s are open, then the rear sills will be on too. they are all on the same circuit. so no need to freak out, its just the way it is. :D
they look tops at night though B)
Evo
Just a note on wiring for the door sills.
Rather than using the wires running along the side of the car as in ( http://au.toyotaowne...847entry25847) that KT_haha wrote about
you might try using the connector that I identified that has the door switch connections in it.
On the 2002 Conquest wagon it is under the dash on the drivers side above the the kick panel and is strapped with tape to the wiring loom.
See:- http://au.toyotaownersclub.com/forums/index.php?showtopic=27063&view=findpost&p=386994 photo.
This shows the connector and the connections I used for the under dash LED strips that
come on when any door is open, not to dissimilar to getting the sills lit when any door is open.
Check this works OK in your car with a multimeter before connecting lights.
Hope this makes things a bit easier to get access to the door switch connections.
soundbyte
noice!!! i thought the chrome/red on the black stivo was not really appealing...
thanks for being the guinea pig, now i will get mine LOL :P
i think i might spend some time to paint them black :P
and when there is blue, i'll order some :D
I've got blue ones??
haha,
as do I :P
Evo
haha,
as do I :P
Evo
..............................................................i want them
hey fellas,
in regards to doors sill,
where can i get the sportivo ones?
and how much am i gonna be hit up for them??
      Remote start
    5. 9
    6. 9
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
