New Wheel Fitment Issues
Tried to put my new 17's on today, they fit great, but.
Only problem is the wheel studs come about 1/4 through and just stop.
Looked in the bag of nuts and they aren't lug nuts, they're lug bolts.
Lug Nut (what I have)
post-23516-0-03094800-1313310839_thumb.j
Lug Bolt (what I got with the wheels)
post-23516-0-99108100-1313310876_thumb.j
Heres my problem
post-23516-0-45287900-1313310746_thumb.j
post-23516-0-26799200-1313310919_thumb.j
Chatting with my mechanic and his advice was to sell them :angry:
But thought I'd just try here first to see if anyone had any ideas?
Obviously lengthening the studs comes to mind, but the gap to even put the nut on doesn't look like it would work & even if it did wouldn't be able to put a tool around it to tighten that for sure. Unless I get a hex lug nut? if that even exists...
Am I screwed? Please offer up your advice :)
Edited by RollaRollin
Just checking out D1 nuts, they pretty much have a hex head to do them up?
Only problem is that the wheel studs don't protrude that far from the wheel, which would lead to an inferior fit.
Does anyone have a spare hex head lug (D1) I could try out that could send me? :)
you can get the hex nuts from supercheap/autobarn type places, i paid $1.50ea
and also extended studs for around $4-6ea
unless ur after the ultralight weight wheel nuts :whistling:
Edited by rthy
Heres my problem
why are they like that? is there a spacer attached to the wheel? the centre hole large enough for the hub?
Yeah guys they are definitely euro wheels
Which is why hardly any stud shows through,
The wheels are used to having a lug bolt not a lug nut.
Only thing I can think of...
Is is possible to extend my studs?
Or is it just not worthwhile
Did a search and not much came up
you need to buy and install longer wheel studs, there's not enough thread poking through to secure the wheel with the current studs on those wheels. Best to sell the wheels and buy some that fit correctly.
Is installing longer wheel studs even worth my effort?
I was really happy with the wheels until i realized this stupid mistake
New hubcentric wheel spacers got me thinking, with long studs, but they'd be probably $300 for the set.
Apparently they were from a Barina juvenile, but being BSA I thought they would fit too, but nope, hardly any wheel stud poking through.
Which I'm assuming uses bolts instead of nuts.
Got a mate over today who knows a fair bit about cars.
He pointed out that the rims are tapered inside, and that there was plenty of stud there it just didn't look like it. :idea:
An hour later, $40, I have 16 new tapered wheel studs that are hex head.
FINGERS CROSSED TOMORROW :unsure:
You guys will be the first to know
    2. 83
    3. 26
    4. 2
    5. 2
      Head Unit with Apple CarPlay
    6. 3
      Invisible Instruments fix
      Can I use USB hub to get more USP ports?
    10. 1
