Take spoiler off
WUPA
Hi guys,
Need your help again.
I own a toyota aurion touring in melbourne. Now I want to takethe rear spoiler off, do you guys know where I can get it done? Can I bring to the dealer and ask them to do it for me, or do I need to go to somewhere else? How much approximately including cover the holes on the rear hood? If I take it off by myself, if anything's wrong, is it under warranty?
And another question is about touch ups. I got some serious scratches on both front and rear bumpers, where I can get it fixed or have touch ups? Are they expensive?
Many Thanks!
Hi guys,
Many Thanks!
www.yellowpages.com.au
I am actually being serious and not trying to be a smart *****. If you want a quote for a job then your only real option is to contact a company and ask them. It's how everybody else does it, forums unfortunately can't give you every answer. Try doing a search as well as you'll be surprised what has already been covered
Hi guys,
Many Thanks!
Go to a panel beater/smash repairer and get quotes, they will be able to do the lot.
1stkill seems to have a decent repairer that he uses, may be worth asking him.
Hi guys,
Many Thanks!
touch ups ? like how big are the scratches ? a cut and polish should get them off if they aint too deep,
with your spoiler, its no hassle in you taking it off, just remove the boot lining and there should be bolts underneath, the only problem you will have is the holes. If you get it professionally done, that means they have to cover up the holes and respray the boot, where abouts are you in VIC ?
That's a lazy attitude you have there Trent. you're not being very helpful at all.
he's already got 5 stars ;) :P :D
Thanks for your help. I live in Mel city
Hi guys,
Many Thanks!
Im pretty sure aswell the touring doesn't have a centre brake light if not you will either
a) replace the rear shelf with a ATX version (contains the moulded brake light.
B) LED Stip in Red stuck to window.
Removing spoiler imo is bad idea :\ really should have just bout the ATX model...
      Centre Bearing Replacement
    3. 6
      maps in 2017 Camry Altise
    6. 5
    7. 4
      Front Cameras
    9. 51
    10. 51
