Something that ALL Sportivos should read and know
Evaporator temp circuit location on 2005 kluger
Trying to find evaporator temp circuit on my daughters 2005 Toyota kluger any help would great thanks -
Rav4 CVT FAILURE
Hi Janine, I am sorry to hear of your dilemma..Yes I would suggest a second opinion either at Toyota or another reliable mechanic. It is rare to have a CVT failure at such low mileage but it can happen. As you said it had not had a good service history it could be that the transmission had a tough life either towing or driven hard. Please update us on what the outcome of the second opinion turns out too be, if it requires a replacement transmission someone may have a source or advise where to locate one for a good quality replacement unit. KAA -
46
Ln106 Hilux Engine Conversion.. 3l to 1kzte
Hey guys! Not sure if anyone still looks at this thread... i have a 1991 2.8 diesel Hilux with mint running gear but the body is rusted up. I was was wondering what the possibility is of taking the engine and gearbox from my Hilux and putting it into a 1996 Toyota Hilux surf body. The main problem i think will be the fact that my Hilux has no electronics and the surf does... -
4
Converting my corolla into a Sportivo
i own an official TRD Supercharger that's OEM for your Corolla if you're interested as I'm selling it. It's bolt on, average 5 hours but if you take your time possibly take a day. If you want to stay naturally aspirated, then do the engine swap. If you're looking for forced induction, this an official TRD supercharger can be considered. -
16
Official TRD Supercharger for 1ZZ
parting out the TRD Supercharger. If anyone is interested please drop me a line. -
Ln167 crankshaft damage what are my opinions
Hello I'm looking for help with my 1998 toyota hilux ln167 3L diesel with the 5L motor as i started to notice a knocking noise after I did a 4wd trip and found out it was a the harmonic balancer as I was taking it off the harmonic balancer was really wore in the key way and the same on the shaft of the crankshaft, do I need a new crankshaft? Crankshaft https://photos.app.goo.gl/GHoXsXsdCJeDsNrz8 Harmonic balancer https://photos.app.goo.gl/9iUKALStsVjWZyzX7 -
iPhone intermittently connects to CarPlay or visa versa?!
So I have changed out multiple cables. I don’t believe it’s the phone but rather the cars electronics? I plug the usb into the port near handbrake middle console. sometimes Apple CarPlay comes up and others not . Phone is being charged so a connection is occurring electrically. ideas ? cheers -
Gents, I want to narrow down possible cause, as I'm not a pro... - I can lock/unlock all 4 doors with key. - I can LOCK all doors with fob, when unlocking with fob, driver's doors stays locked. I found the small plastic hatch on door panel which moves when you lock/unlock doors wont move properly when locking/unlocking. Is this likely to be a mechanical issue? Should I just put some grease on cords inside the doors? Or issue could be with locking actuator? Thanks for replies! Cheers. Martin
