HOW TO REPLACE THE ROTORS???
leasaunce
get the calipers off and the mounting bracket and the rotor will come straight off, its pretty simple.
Yep !
The wheels hold the disk to the hub.(no other bolts)
As "darkeh" said remove caliper(2 bolts very simple : DONT LET THE FLEXIBLE HOSE TAKE THE WEIGHT OF THE CALIPER, USE A CABLE TIE TO HOLD THE WEIGHT) then disk will simply pull off.
