performance chip for 2012 aurion
Sean K
Not feastible mate. The only way you can increase your car's performance is supercharge it by sourcing parts from same supercharger supplier the TRD had on the Aurions in the past. But not just the supercharger, you need to upgrade your brakes from standard to brembo to handle that power
Never heard a piggy back ECU made available for the 3.5L donk! DeafDave is right you have other stuff to worry about such as brakes, suspensions etc to worry about beside sourcing the same supercharger the TRD used some years back.
The TRD version from memory struggle to handle the additional 40kw of power, it was more than what the chassis could handle. Even if you do enough mods to alleviate the problem you still have a very intrusive traction control kicking in as soon as you go a bit happy around a corner.
      300 series turbo issues
    2. 8
    3. 54
      Stout Owners
    4. 2
      New Member
    6. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    9. 199
