2009 Hilux tail gate SR to SR5
victos
I,m pretty certain the SR has what Toyota calls a ( J Deck ) and the SR5 has a ( A Deck )
J Deck has hooks on side/tailgate and A deck is all smooth.
Edited by CONROD
I yeah wanted to put the smooth tailgate on on.
But sounds like the shape is different,
Edited by victos
  • 4 weeks later...
They are the same and it can be done. You need to flip the latches 180 degrees and then the SR5 tail gate will go on. ( I should clarify that the early models which I think is 05-08, need to buy the latches from a later model as they have a different catch, but it still can be done.
Go check out the Hilux.net forum where you can see it done.
Mark
post-34719-0-19626300-1447485773_thumb.j
Edited by mazman
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
    4. 12
    8. 3
      1VD - Ticking Noise
    9. 3
    10. 5
