Sportivo Seat Swap
ItsNotACamry
So I’m looking at swapping a wrecked ZR6’s leather front seats into my 2011 Touring. But the drivers seat is electric and the passenger seat is manual, and both the sportivo seats are electric.
im just wondering if Toyota left the wiring loom in the car somewhere because they al use the GSV40 chassis, or if Its possible to splice off the drivers seat?
6 minutes ago, Metal_Head said:
Hope this helps
Yeah that helps a lot mate, another question, notice any difference when driving it, Was it worth it and do you move around substantially less?
It makes the inside of the car a great place to be haha. Improves the feel of the car 1000x..
As per my post, it will make life easier if u get the zr6 white plug on the passenger side along with a little wiring so u can join it to ur existing wiring, and steal the power from ur drivers side. I've adjusted both seats at same time and fuse is ok
I know my left knee sits very close to the centre console, I can't remember if the original seats were the same. Just make sure all electrics work. I found with my drivers seat, the up/down base adjustment wasnt working. I couldn't figure out if it was just a dirty switch as the plastics around the base are hard to remove so I left it
Edited by L4WL3SS
  • 2 years later...
    5. 3
      1VD - Ticking Noise
    6. 3
    7. 5
      Ae92 genuine low ks 70800
    9. 1
      BATTERY in Klugar 4 years old
