NRMA ARE BEING GHEY...
Landcruiser 200 (2012) suspension swaying issue
Hi seismic60 curious if you managed to get to the bottom of the kdss issue? I have a 2017 LC200 Sahara with the same issue, very frustrating need to figure it out. Thanks -
31
Whine in Transfer Case - 2011 Kluger
My 2009 Kluger has a fairly loud whine in the drive train and getting worse over the last 10,000ks.....has 142000ks all up...been to 2 places to see if they can identify where it is coming from ....,been on the hoist and used a stethoscope ect ,but no definative answer..they say the noise carries so difficult to identify....i feel there must be way to sort this problem so any ideas will be greatly appreciated.... Cheers Ken -
Advice on new Head Unit for Corolla Levin ZR 2011
Hi there am new to this forum, a bit overwhelmed from an online search - seeking advice on a good Japanese or US made head unit for our 2011 Corolla Levin ZR and also a reputable installer in Melbourne region, Victoria. Many thanks in advance -
4
Hi My 2021 Rav 4 has that same problem which has never happened with any of my cars over the past 53 years. It’s only done 65,000 km and I’m hoping I can push some acknowledgment while under warranty and hopefully Toyota can get it repaired. Watch this space.- 1
GR mods
Hi all, New member here. I just bought a 2025 White Hilux GR Sport. I want to get bigger side steps and keen to see what else people have done to theirs such as fatter tires etc. Mine is white and I will tint the windows. Thank you. -
hi ihave same sort of problem but wierd turning left or right under some load speed no go take foot off pedal push down again goes off had fuel filter in tank changed didnt fix it my mechanic disconnected battery for 5 mins conected up again seemed to fix it but 4 weeks on starting to do it again only a bit worse back to mechanics on tues for another go at it. if no joy may have to go to toyota dealer $$$ to get them to check it out interested if you get some rsplies cheers -
Hi there
howdy, my name is Pete, i recently bought a 2016 diesel rav4 and we're having a bit of a problem with it , hoping i can find a solution here , I'll post it in the rav4 section. cheers -
Air Conditioner not workimg
