Club Name
69 members have voted
4lo flashing ABS,traction control, brake light stay on
Hi help needed I've a 2009 150 series prado and started the car and 4lo light is flashing , ABS , traction control, hand brake light stay. Tried taking batteries lead of for couple hrs nothing. Scan tool nothing. Batteries are good alternator is good ,looked all over terminals, earth leads all looks good, drives the same I've no idea -
Android auto not working Toyota corolla ascent sport hybrid
HI guys Recently I bought a Toyota Corolla ascent sport hybrid sedan 1.8l, but when I try to connect my android phone to the vehicle it doesn't connect to andtroid auto, android auto is not working. I know that the version of the multimedia unit is outdated and needs to be updated. Therefore I searched for multimedia software updates on the Toyota website with my vehicle's VIN number, but the Toyota website doesn't recognise my VIN number. My unit Model number is DCU 19TDT20C-EAP7 MEU 19TMT20C-EA02 I cannot find latest update files for this model. Please help me to find the latest update files for the above model. -
Please help Reverse Trigger wire harness for Camry Hybrid 23
Dear all I have a Camry Ascent Hybrid 2023 with standard version, 7 inch touch screen Fujitsu Denso FT0106B head unit. Today I removed the head unit and replaced with the Alpine ILX-F511A and connect the plugs by Aerpro wire harness. I connected all the plugs but there is a 28 pin plug does not have the wire harness from Aerpro cable. Everything is working except the reverse Camera. I connected the reverse trigger wire to Aerpro reverse trigger but the camera does not work when I change the gear to reverse position. I think this error comes from the 28 pin plug which is not connected. If someone knows which wire harness color and which pin is the car reverse trigger please help me with it. And the FM radio is not working too, I do not know which car wire color to connect the blue wire from antenna connector too. Thank you so much. -
10
rear wheel arch hole covers (3rd row seats removed)
I have purchased the rear seat hole covers for my 2024 fortuner and I am very pleased with them. It comes with all the necessary fixings. The plastic finish is a little different but it's ok. Very happy with the service as well. Nautia engineering in WA. -
Drive shafts
I paid $1200 ish to get a pair fitted to my aurion couple years ago. Thats supplied & fitted. Apparently it wasnt a fun job. Id get the mechanic to source the parts incase theres an issue in the future. -
FUSE BOXES ALLOCATION - 1996 SUPER CUSTOM Model (Import)
Hi All we have a 1996 Toyota Hiace Super Custom (Import), the Cigarette Lighter doesn't work & need to allocate the Fuse Box. if anyone can steer me in the right direction, would be greatly appreciated. -
10
Vibration through body (not steering wheel) under acceleration
Well, new tyres, a proper wheel balance seems to have done about 90% of the trick - the car now drives like it once did. The only thing is that a wheel bearing was called out as "completely stuffed" and as it is so bad, the only way to fix due to wear on the knuckle is to replace the whole thing. Quoted $600 for the repair and no parts for this until mid next week. Once this is replaced I will update if back to 100% or still more problems. I was thinking that the aftermarket CV shafts could be to blame - very glad this turned out not to be the case. -
possible fit 2015 kluger Grnde driver seat on 2019 kluger GX
Is it possible to fit 2015 Kluger Grande electronic driver seat on 2019 Kluger GX ? what i should be aware of before buying one online ? -
front brake calipers
anybody know where i can purchase new front brake calipers in Qld drawing a blank everywhere i go also will corolla or camry fit car is a 2011 model
