high fuel usage
Hi guys i have an 2009 with a 4l petrol and has suddenly started using more fuel. was wondering if any one else had this problem at all. no fault codes, new spark plugs thinking it may be o2 sensors or blocked cat, any help diagnising would be great cheers -
Rukus for sale
Hi, I have a one owner top spec Rukus about to be placed for sale in Melbourne. It's a deceased estate and likely one of the cleaner and low mileage examples available for sale. Thanks. -
Wanting to buy ruckus
Hi I don't suppose you're still after Rukus, I have a very clean one owner top spec example about to be up for sale. -
That's expensive for a steel key. Https://www.keysocallaghan.com.au -
Newbie
Welcome to the forum Kevin, And no naturally we love our Kiwi cousins..hope any questions you have can be answered I am sure many will always try to help as there are some great minds on here. KAA -
Is the Hybrid FWD download capacity on towbar an error?
Hi all, We managed to snag a fwd Cruiser recently from a dealer. Great car but I’m reading about the tow capacity and towball download capacity and it’s 480kg for towing and 50kg download limit. This seems extremely conservative. The FWD Petrol version is 800kg tow and 85kg download. Pretty disappointed in these numbers as I added the tow hitch for $1200 just so I can add a bike rack but based on the 50kg download limit I’d be hard pressed to put 2 bikes and the rack on it. Any ideas why these numbers are so low? Download limits are usually around 10-12% of tow capacity so maybe they just haven’t considered this? -
P0356 - Ignition Coil 'F' Primary Control Circuit/Open
Thanks Ashley. Got lucky last time too as it was cylinder 4 last time a coil failed. The luck will eventually run out tho...- 1
Your are fortunate that cylinder 6 is easily accessible on the right hand side of Bank 2 which is the one closest to the front of the vehicle/radiator. Cylinder layout for the 2GR-FE is in the following URL: https://www.toyotanation.com/threads/location-of-cylinder-6-v6.470305/
