blody annoying.....
Can any one tell me how in the hell i can turn that anying blody reverce beeping **** OFF it drives me crazy....
and also the beeping when you have the driver door open with the key in...
has any one taken the little speaker out or cut wires???????
pleas help me out it dose my head in....
Thanks ...
u driving a semitrailer or something? hahaha!
are you serious your car (im guessing its a corolla) is beeping while reversing?
did you buy your car new or 2nd hand?
if its 2nd hand i guess its a mod that the first owner did. they may have changed one of the reverse tail lights to one of those that make the beep noise when its lit.
if thats not it, hope someone else can explain it?!
personally i wouldnt mind the beeping reverse... i dont wanna run over my kid.
The reverse beep is a standard feature for all Sportivos because the six speed puts the reveres next to first gear. Everyone that's ever been in my car always laughs at it. Unfortunately the beep can only be heard from the inside of the car so it doesn't serve as a warning to other while reversing.
As for disabling it, do a search. This topic has definitely been covered before. Someone managed to disable it by disconnecting the speaker if I'm not mistaken.
from what i have heard, you play with the reverse beep anywhere but with the speaker, the ecu will go into limp mode.
if u get rid of the speaker, u loose the speaker for all beeping reminders.
Its just a beep... its not like u are in reverse for more than 30 seconds max... get over it and deal with it, the rest of us do.
Agreed!
sorry 2 change the subject but whats annoying me is trying to figure out how tayles and mikey t morphed their cars to look like that! so cool howd you do it? hahaha
HAHA :D
PM Carlo - IZZ-FE. He'll give you a Rav 4 conversion :lol: if you have a side-on pic of your car he can tell you how to do it. Actually there's a thread on OWF about how to do it ;)
heya i found the thread :P
i knew it wasnt that hard to do! it makes total sense now.. must try this on my old landcru23r... it already kinda looks morphed muahahahaha!
      maps in 2017 Camry Altise
    3. 5
    4. 4
      Front Cameras
    6. 51
    7. 51
      1kzte throttle body
      Aftermarket parking sensor
