This is a place that we can all post and compare our 'baseline' sheets for our mods etc.
There are NO comments to be posted in this section. Just pictures
Any comments are to be made in their respective areas.
  • 5 months later...
Posted (edited)
I had my 1st dyno run on Saturday.
Peak hp: 107.4 kW
Gear: 4th
Dyno: Dyno Dynamics
Mode: Not sure (I assume shootout)
Ambient: 36 Celsius
Fuel: 95 RON
Not bad for my only engine mod being the CAI, considering I had crappy fuel and the hot day. But what's with the torque hole low down in the rev range?
Anyway, scans for kW against AFR and kW against torque (N, not Nm) are below:
Edited by oz_viking
here you go this one has the stock, CAI with the K&N pod and the TRC CAI with the TRD pod.
Posted (edited)
Completely stock-as-a-rock, AUG 2004 Pre-facelift Toyota Corolla Sportivo Dyno attached.
Peak hp: 107.2 kW (at the wheels)
Gear: 4th
Dyno: Dyno Dynamics
Mode: ShoutOut
Ambient: 25 Celsius
Fuel: 95 RON
Tyre Pressure: 40psi
Edited by sport1vo
  • 3 months later...
Posted (edited)
Power @ wheels with TRD CAI and BP Ultimate fuel: 114.1kw @ wheels
Dyno Dynamics 4WD Dyno in Shootout Mode
Gear: 4th
Ambient Temp: 19
Tyre Pressure: 34psi (although it says 50psi)
Edited by ZEEROLLA
  • 4 months later...
completely stock, not even a differnt air filter.... just hit 6,000km on then engine
2005 Corolla Sportivo
1.8L na - stock
4th gear
  • 7 months later...
Posted (edited)
Edited by ar44
that's stock? nice... better then the 115.2 I got and that was considerred a freak number :)
nice platform to build from
      Remote start
    5. 9
    6. 9
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
