Just wanted to say thanks for the welcome on my first night and look forward to many more to come
Great punch of guys
Thanks again
Foose
  • Replies 3.8k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
i got home from my night out at 9.... i was gonna come visit... was too busy playing with my new camera tho.... next week i might use it :D
Work is sending me back to Brisbane so I will catch you guys some time over there in December....depending on how long my car takes to come over
Welcome! (another guy to talk F1 with :D)
BTW anyone heading out tonite? I'll be taking my car to the DDR yO workshop 1st after work, so it depends how long im there.
Hey, I was looking to get a lightweight battery and thought I'd throw out some feelers here. I don't want the hassel of spreading this buy outside of Brisbane. I don't even know if they would even do a discount. But anyway it is a Braille battery, http://www.brailleauto.com/productcart/pc/...amp;idproduct=1, price is list at $260 and are located in Everton Park from a place called 'The Racing Room'.
Info for the lazy;
B14115 Battery Specs
Casing: Polymer Plastic
Weight: 11.5 lbs (about 5.2kg)
Length: 5.8
Width: 3.4
Height: 5.8
Pulse Cranking Amps: 904
Cranking Amps: 486
Cold Cranking Amps: 360
Amp Hour Rating: 15
Warranty: 1 Year Free Replacement
For comparison here is the Odessy equivilant, http://www.odysseybatteries.com/battery/pc680series.htm
Deka do one too, the ETX20L. As used by DHC09. Specs:
* Length: 6 7/8in.
* Width: 4in.
* Height: 6 1/8in. (height without plastic spacer)
* Weight: 15.5lbs
* 12 Volt
* 19 Ah @ 10hr rate
* 270 CCA
The others are slightly cheaper though, but just thought I'd see if there was any interest in the Braille.
Planning to hit the twisties tomolo nite. Will show up at 9 at the usual place and then head over a little later. Harry "might" be coming with; more the merrier :D
I will be out tomorrow nite. Is my seat reserved if we hit the twisties?
Info for the lazy;
Length: 5.8
Width: 3.4
Height: 5.8
Cranking Amps: 486
Amp Hour Rating: 15
* Length: 6 7/8in.
* Width: 4in.
* Weight: 15.5lbs
* 12 Volt
* 19 Ah @ 10hr rate
* 270 CCA
You want batteries Dave? My best mate sells batteries for a living. I will see what he can get you. I know he can get the Deka's too...
Posted (edited)
I like the Braille ones since they are the lightest I have found so far and is actually designed to be used in a car. The Deka one, AFAIK, is just a snow mobile battery. It uses the same case but weights about 2kg more.
And so far I am on for tonight.
Edited by SuperDave
I'll be there to pick up some "goods" from azn dave.
Dave has decided to be soft and not head out tonight :P
so who is out tonight?
I'll be there ... in the "new" wagon, of course ... :-)
I'm with DHC on this one. DDR sticks together :P
Just make sure you get all the salt and sand out of the chassis! A sprinkler underneith it for a while did the trick nicely, untill water resitrictions turned up.
All good mate. I used the high pressure jets on the island and gave it a good underbody blast. I'm in the process of tracking down some videos of it going through some really fluffy sand.
      Remote start
    4. 9
    5. 9
      Turboed Corolla Overbuilt?
    7. 3
    8. 3
