ZRE HOT HATCH POTENTIAL + ZRE182..pg117
Rear speakers?
On my dual cab SR rear speaker wires and Plug were already in place, I just got a couple out of a SR5 from the wreckers, perfect, Get yourself or make a Memory saver, ( 9v smoke alarm battery, 2 alligator clips, and the plug and 2 wires from Jaycar ) worth every cent and saves resetting everything if battery is needed to be disconnected Safety 9V Battery Clip - Highest Quality | Jaycar Electronics -
Centre Bearing Replacement
Check if there is a Front Arrow and the centre bearing is actually running in a straight Plane, what are the uni's like, For you to experience Shuddering, its pointing to a Flogged out Uni. Don't know about the smell of burning rubber, if you greased the uni,s might be just grease on the exhaust. Put it in gear 1st, hand brake off and get someone to rock the vehicle back and forth and get under it and visually look and feel each and every uni and also the slip joint near the centre bearing for excessive play -
RAV4 19" wheels on Aurion
Wheels arrived today & I had time to sand one of them with a SIA green superfine pad (600-800g) Much better already 👍 Regarding tyres, I've purchased a set of Nexen N'fera Su1 in 235/40r19 for $220 fitted which is pretty good for a mid range tyre -
1992 1hdt both blinkers flashing together
I have changed the flasher can, not the problem. Wondering if it could be the multi function control stalk? -
Celecia GT Four ST205 Mag Wheels
Hi, Does anybody know where I can find Celica GTFour ST205 original mag wheels. I live in Sydney. Thanks -
New member
Perth based and have had my 2005 GLX HD100FTE from 0kms, 357Km now and we are both going strong -
Tivo Restyle.... Haters gonna hate
It’s not bad looks like a jdm model I forget the name -
Could you check part numbers for space saver in new shape?
Hi guys. I have a new shape 2024 C-HR in the UK. Over here they don’t have a spare wheel, but it is shown in the owners manual. As far as I can find out, some models in Australia have one. Could anyone be so kind as to have a look and see if there are any part numbers etc on the foam supports so I can ask my UK dealer about it. Thanks very much 🙂
