Top Gear Australia gets a new host
New member seeking advice for parts
Hi guys! I'm Alberto, I just finished importing a HZJ73 from Japan and I love it! The car came without spare wheel holder and it seems discounted so I don't know what do to. Someone knows where I can find it or what else works as replacement? I don't mind if is not oem part as far as it works 😅 I'm based in Brisbane if it makes some kind of difference Pictures attached as reference -
39
Pics of my Kluger steering wheel removal
What are you trying to say Don? _______________________________________________________________ skysmotor.co.uk sells the following products online: ac servo motor, geared stepper motor, stepper motor drivers, planetary gearbox and can be purchased online if required. -
14
1zz to 2zz
hey daniboy this is one of those situations where i’m stuck and going through old forums haha currently doing a 2zz swap on my zze122 wagon and i’m having a fuel pump not priming issue, any chance you could respond back 10+ years later -
Can I put a 2010 bumper on my 2008 Camry ?
I have a 2008 Camry altise and recently damaged the front bumper and i'm wondering if I can fit a 2010 sportivo bumper on to replace it. It looks like it fits I know I will need to get new headlights for it to fit but do I need to do any modifications or will all the plastic clips and screws line up ? -
5
Anyone else tried these seat covers ?
these seat covers look pretty good, but I've had bad experience when trying to fit some cheaper ones I bought online - they say custom fit, anyone else tried them ? Would love to know before I buy them, thanks all https://mycustomcar.com.au/ -
Digital Speedometer
Hi did you figure this one out? I have the same model and been unable to get it digital as well -
am2 fuse blowing
Hello, i have a 1996 starlet The problem is when i turn the key the fuse blows, and i have been looking over the wiring and can’t find any shorts or damaged wire. The car would not crank over because of the fise blowing. I found out that if i disconnect the transponder key ecu the fuse is holding, but as soon as i connect the transponder the fuse blows. So i wonder if there is something I can try out? should i just buy a new transponder box or is it something else i could try? and is it not kinda wierd that the box is the problem? I have looked inside the box and cant see any corrosion in the box -
Toyota Celica '96 5S-FE no spark
Hi everyone, I have spent too much time on my Celica and even my mechanic is stumped at figuring out the issue so any tips will be appreciated. Here is what has been done, immobiliser disbabled, distributor replaced, igniter replaced, EFI relay replaced, and EFI 15AMP fuse is not blown. I tried jumping E1 and TE1 in the diagnostic port to try and get a code from the CEL but it doesn't light up, I think it might be burned out so I will have to get on that. I am now clueless about what to do next, it could be the ECU but I can't find any pointers too that. -
Toyota Camry 2003 Driver seat recline issue
Hi guys, so i just bought a 2003 camry. So something is wrong with the driver seat (manual recline). When i recline it at a certain place it locks in but if you put ur body force the seat tilts back a bit and locks to a different position. Looking help if someone knows whats wrong and how to fix it.
