[Updated links now with pics] 2ZZGE-New Intake Manifold - Street version with Q45 Throttle body
I bought my 2006 ATX Aurion back in 2015/2016 with 160,000 KMs on the odometer. 8 years and 100,000+ KMs later, still going strong. I do a lot of preventative maintenance with regular engine oil changes. Transmission fluid has been changed and also the coolant. In that time period, I have replaced the water pump, alternator and both front and rear struts/shock absorbers. In hindsight, I have replaced brake pads much sooner than needed. Overall, future maintenance should not be expensive. -
Hi Reece, I've been trying to reply to this post, but for some reason the site wouldn't let me. On one of my morning walks, with my dogs, there is a Hi Lux tub sitting on the nature strip. I know nothing about it, except that I think the owner could well sell it, but hasn't. I will attach a photo for you, and if you are interested I will email you the address, if you PM me with it. Note that it is in Geelong, Victoria, maybe a good reason to visit. . Herb -
Fitting on the headlight bulb appears to be the usual twist to release and lock. Definitely do not try to brute force the removal because you will definitely break something like the headlight housing. Suggest that you use some WD-40 and have a real good look at the existing bulb using a mirror and a good light source. Then have a few wiggles attempts to loosen the existing bulb so it can then be removed. If this does not work, then time to be smart and not stubborn. Far better to pay a $15 fitting fee than the exorbitant cost to replace a damaged headlight assembly. -
help with clutch
High mileage camry
1981 Hiace ignition upgrade
