just wonderin..... any comments would be great..
8
PZQ60-00525 Issue
Hey mate! Hoping you’re still here. How’d you go with this? Currently trying to diag the exact same thing in my rzn169r 4x4 2.7l hilux. Smell is getting pretty unbearable but all fuel lines are dry and nothing obviously wrong with any vents or connections (on the surface at least). No smell when idling. Mostly just while driving, especially after a long stretch at high speed or uphill. Noticeable inside, most strongest in the rear right passenger seat - right near the fuel door. -
Head Unit with Apple CarPlay
Hi Wifes_Rav4 i just bought the Sony AX5500 through the Sony site ( where i get a bit of a discount ) now i need to find the right hardness for Headunit USB retention Steering wheel control retention integrate the current reverse camera what is the best way to find out and where can i get them you think before i find a installer to get it done - trying to find the cheapest way to do it hahah -
Aurion "wobble"
Did you find the cause of the wobble? I have been having this same issue which has gradually become worse. I have replaced the drive shafts and motor mounts, all bushes and front shocks, wheel balance and alignment. I have dropped my trans oil today and found some grey residue so I'm thinking it maybe a failing transmission. -
Navigation in 2017 Aurion
HI, I've bought a 2017 Aurion and just wonder if a NAVIGATION system is included or possible via Bluetooth? -
Side steps
hi have a n70 Sr hilux wanting to know if n80 side steps would fit are the brackets the same cheers -
Hello, Does any own a Toyota Aurion Sportivo 2017 model that they could give me a ride in around the block as I am looking to buy this model car or a 2017 Toyota Aurion Presara with sports rims. WILL PAY $50 FOR THE RIDE DEMONSTRATION. Thanks Angelo
