Just a question to everyone, how far do you have to depress the park brake before it actually starts to stop the car from rolling, took my car to the service dept. yesterday and was told it was normal. (my park brake goes nearly a foot in). thought this was iffy as my family's honda odyssey and merc, both only need to be depressed about 10cm. Am i subject to cable stretch?
cheers in advance
mine is about 10-15cm and it wont move on a slope, a foot sounds a bit much....u can adjust them u might just need to tighten yours
lol i dont think you'd want to DIY on something as important as your handbrake.
next time you get your car serviced, just tell the guy that you also want your handbrake tightened. same thing i did.
too bad a few weeks later, the cable was stretched again.
mine can go almost to the floor before it was stop rolling back on a slope...
not a major issue, but i'll be mentioning it amongst the 5 other things that they need to fix... :rolleyes:
Why not? Its only adjustment of the peddle. It’s not as though he is pulling it to bits of anything. But if you want to adjust the rear shoes you may want to be a little more mechanical minded, but still not that hard.
To properly adjust the handbrake, you need to back off the cable adjustment, adjust the rear shoes and then tighten the cable to spec...
Doing it any other way will stretch the cable...
  • 6 years later...
I have the same problem, effectively no park brake, I have 2 aurions and did the adjustment at the disc when I replaced the rotors, sanded the inner part of the new rotors with co**** paper, roughed up the brake shoes, cleaned it all and adjusted. It works very well now.
Question - where is the cable adjustment done? Wifes car has the pedal going to the floor almost and it still does pretty much nothing.
the cable adjuster is located next to the park brake, you will need a 10mm spanner and a 10mm deep socket to adjust it
Thanks for that info, on my 90 000km aurion the adjustment at the pedal was at its loosest, removed rear discs and turned adjuster there about 6 clicks on each side,( I think I should have done another 6 clicks), then tightened the cable at the pedal about 10-15 turns and now its all working very well.
Also took the opportunity to brush the dust... off all the brake parts, run some rough sand paper over the park brake shoes and the inner surface of the disc where it rubs.
I live in a smallish town and hardly ever reverse, even to park and I think park brakes adjust themselves when you reverse - at least thats how most used to be made, so that might explain why the in brake adjusters were all the way in.
If you get a set of vernier calipers, the measurement on the outside of the shoes is 189.7mm, set it to that and it should be pretty good
Mine gets adjusted when ever it has a service, if who ever is servicing you car isn't doing it then they aren't doing a proper service.
Oh and 3 clicks roughly when it's had a service but after 12 months it's about a foot
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
