lift light
shao has led's which do this ....check out his garage ;)
he has them set to 2000, 4000, 6000 and 8000 i think???
these leds can be reccesed where ever you want :) you are only limited by your imagination
nope, 3 blue and 3 red.
3000-4000-5000 (blue)
6000-7000-(somewhere just under 8000) (red)
each LED itself is a shiftlight kit. each are around 50bucks for the red and 60bucks for the blue ones. they are made by chiptorque, it's called the Xede shiftlights or something. my shiftlight project was a perfect example of scope creep. i only wanted one little light to begin with. then it became 2, one for lift and one for shift.
then it grew a little bit more from there...
u can get those kits from autobarn or off autospeed.com
Edited by shaohaok
I've also been thinking of this for a while, but I'd rather an F1 style high RPM barage of colour, and also so it doesn't annoy me during my everyday driving.
I'd stage it thus:
5000 RPM - Blue
6000 RPM - Green
7000 RPM - Yellow
7500 RPM - Orange
8000 RPM - Red
Most likely position would be the under-side of the dash display
The theory being once the Blue goes off you are safe to downshift, right into the powerband... :D
Edited by Blue_Stivo
is your last one meant to be at just under 8000 RPM shao???
looks nice :D
and the switch is a good touch, hadn't thought of that but the position is right where I'm looking...
oops yes, just editted the typo.
i spent weeks thinking and pondering about it. initially i wanted the LED inside the instrument cluster sitting flush somewhere in the tacho. but it was a bit more complicated than we thought. so i decided to mount it where it is now.
northy was jumping up and down " DO IT DO IT DO IT DO IT DO IT " and ripping up the dash to look and see how we'd do it. poor sod almost cooked his whole arm with the soldering iron at one stage :P
Edited by shaohaok
I was considering this a while ago, I wanted a couple of green lights to light up when the coolant was @ 70 degrees to show lift was available, then a red light to come via an and gate when the coolant was at 70 and the revs were at 6,200
I never got round to thinking about it.
  • 1 year later...
polished up with a switch to turn it all off if starts to annoy me
so yeah, as soon as i stop seeing red lights when braking, it's safe to downshift.
don't ask me how it's wired. ask northy.
just wonderring if you still have the install pics?
Guest JDM y0 !
I'd stage it thus:
5000 RPM - Blue
6000 RPM - Green
7000 RPM - Yellow
7500 RPM - Orange
8000 RPM - Red
mad idea ! i love it man. yes the F1 stylez would look cool as. and great idea about the blue light for powerband !
  • 11 months later...
      New Member
    3. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    6. 199
      Advice Please
      A Greenskin
    9. 1
      Car Detailing Recommendations
