Hi All,
Anyone know the difference in the two models... yes we can state the obvious
- Supercharger
- ECU
- Brakes
- Suspension
- Muffler
- Interior
- Exterior body styling
But, is there anything else that im missing.. very interested to know.
Apart from stating the obvious.. Yes, If u'r comparing the TRD Aurion with the Facelift sportivo. There's quite a lot since they've added new features such as heated side mirrors, rain-sensor for the wiper, and few others I forgot what they are. You can find the complete Info on Toyota website..
I wonder how different the engine internals are.
Another thing the TRD has that a non-TRD Aurion has is a transmission cooler.
Also, as SupaTouring has stated, the SL version of the TRD has a slight difference:
The 3500S has a standard steel rear bumper support, the 3500SL gets an alloy extruded rear bumper support that is supposed to help with torsional stiffness.
TRDs have a build plate in the engine bay area with the build number.
Also located inside underneath the A/C controls.
Isn't there also extra chasis bracing in the rear end?
Yeah just found this vid about the extra chasis bracing...
TRD Aurion- Behind the Scenes - Chasis:
and a couple more of interest...
TRD Aurion- Behind the Scenes - Engineering:
TRD Aurion- Behind the Scenes - Design:
TRD Aurion- Behind the Scenes - Philosophy:
Wonder the same... as we know Toyota overspec their engines like the Supra
Meaning ?
Meaning Supra engines are build with better internals than necessary. Hence you can boost the sh!t out of them without them going bang. :lol:
Well I wouldn't say that's always true. Such statement is true for the Supra with the 2JZ mainly due to the fact that the blocks are cast iron which can take quite a bit more than an alloy type block.
      Tyre Sale Specials
      overheated engine
    5. 62
      Tyre Sale Specials
    9. 10
