daikaiju's ZZE123
dyslexik
  • Replies 183
  • Created
  • Last Reply
Top Posters In This Topic
Replaced the Sportivo's Factory Panasonic battery which costs $1050.. which has lasted for so long since i guess it rolled out of the factory in 2003.
post-14950-0-33031500-1312714384_thumb.j
Bosch battery installed. Was not easy to source a battery that had the same height as the Panasonic battery, just so the factory bracket can fit.
post-14950-0-79654800-1336886352_thumb.j
Couple of roaring trumpets to replace the "beep beep" bought back in May.
As at July 2011, the following additional parts have been installed.
  • ES engine mounts
  • Custom engine mount washers (courtesy of Kenshin X)
  • ES rear axle suspension bushings
  • Pedders Polyurethane steering/front control arm bushes
  • Xtreme HD clutch kit
  • Custom made Xtreme aluminium flywheel (3.4kg)
  • Custom Australian made track proven and ADR approved SS braided brake hoses (all corners)
New shoes - Enkei PF01 (17x7 +38) 7kgs. However, it's since been sand blasted and powder coated Pearl white wrapped in Potenza S001 215/45/R17 tyres ($269 each). Bolted on with Kics Racing Composite R40 Revo - Neochro finish.
$1050 for a battery? Is that a mistake? I work in automotive retail and have never sold a battery that expensive..
Yes it is. It's the white battery from factory in Japan. Made by Panasonic. You think $1050 was a mistake (well it isn't), a dude who works at Footscray Le Mans Toyota said to me that the original battery from factory is $10,000!! LMAO!
So I rang around and finally a Toyota mech viewed the part on the system and it is indeed $1,050. It's lasted since 2003 or possibly earlier and would of gone lasting a lot longer only if I hadn't accidentally left both dome lights on near the rear view mirror for almost 2 days. The battery just deteriorated from then on. Had it charged by the battery specialist I had bought the Bosch battery from. After a week, came back and the guy said it's pretty much dead and doesn't hold enough charge for cranking. But has just enough power for interior lights/radio. Even he says he has never seen that unique designed battery before. I told him it's from Japan.
Ok just wanted to check with u that's all. Btw do u have any specs of the replacement battery? Warranty, cca, maintainance free?
Check out the Bosch website and dl the PDFs. Don't u work at a battery place?
Would you track the car at Winton? Looks like it's made for it lol
Thumbs up :rolleyes:
i noticed u have dot4 fluid in ur brake lines... so far so good? i want to use the penrite SIN brake fluid dot4 but very reluctant as our reservoirs say dot3 only.
I use dot 4, as far as I understand and my research so far, dot 4 is coming from dot 3, and dot 4 has no compatibility with dot 3, but never touch dot 5, as dot 5 will damage your car
I am using Castrol super dot 4, cheap and good ($11 per 500ml in supercheap auto), and you require 1.5 Litres (3 bottles) to flush.
and never mix dot 3 and dot 4 together
Edited by ben yip
Just checked inbox and SD confirms that DOT 4 and DOT 5.1 can be used in the car. But DOT 5 cannot. Moh flushed the system out first though and change of brake fluid was done with the install of the new brake lines.
how to check? I would like to check mine too
Also, more info on brake fluid http://www.synlube.com/brake.htm
Edited by ben yip
What i meant was, that i checked my pm inbox, and SuperDave had advised me of the above. My brake fluid properties are provided below:
ERBP: 304°C (Dry), 210°C (Wet)
Min ERBP: 230°C (Dry), 155°C (Wet)
Viscosity: -40°C (1550), 2.0 (100°C)
pH: 7.2
its strange, everyone here is saying its ok to use dot 4 and 5.1. moh and my uncle on the other hand strongly disagree with it and should only use dot3. didnt moh say anything to u when u gave him the dot4 fluid?
Duy, you'll be fine to use DOT4 fluid. If my understanding serves me right, you can go up in DOT but not backwards so if OEM is say DOT 2/3 then you can go up. My stock rating is 3, I've been using Penrite SIN/Motul RBF600 ever since.. which is a DOT 4 I think so..
As SD advised me, dot 3 is not readily available anymore. I mentioned this to moh and asked him what choice would I have. Moh then went on to say the system has to be flushed first before using dot 4 and he did say it's ok to use as long as the fluid I buy is not dot 5. If u want to use dot5 then u must change the brake system - reservoirs, hoses, etc.
      A Greenskin
      Landcruiser 200 GPS
    3. 11
      300 series turbo issues
      Any 2L motors for sale?
      Car Detailing Recommendations
      Proud Owner of Toyota Crown
      Hilux Dash Lights
