Where can i get High-Output Alternator for Aurioin 2010
help with clutch
High mileage camry
1981 Hiace ignition upgrade
Aftermarket Air Intake
Hey all, Just recently bought a 2007 TRD Aurion and am trying to find an aftermarket Air Intake, but am coming to the realisation that there is a very limited market for TRD Aurions. So far the only system I've been able to find is a K&N Typhoon Intake (link here: https://www.carmodsaustralia.com.au/KN-Filters-69-8611TS-69-Series-Typhoon-Performance-Air-Intake-System-Camry-35L-07-11?cq_src=google_ads&cq_cmp=18898892770&cq_con=&cq_term=&cq_med=pla&cq_plac=&cq_net=x&cq_plt=gp&gad_source=1&gclid=Cj0KCQjwpZWzBhC0ARIsACvjWRP893VLnAQsxIZJjcW5Go75b_T2N25rSWBVu6IeDziM2v41bpeyOREaAg1fEALw_wcB), however when viewing specifications for the product it states it fits Camry's from 2007-2011. Further digging revealed this product is an import from the USA hence why it's for a Camry - they don't have Aurions there. I am aware that they both share the 2GR-FE engine so I'm assuming the product will be able to be retrofitted to my TRD, provided the throttle body intake is the same diameter across Supercharged 2GR-FE's and N/A 2GR-FE's. Has anyone else in Aus had any luck sourcing/fitting one of these K&N Intakes, or know of another brand that do them specifically for the TRD Aurion's. Pretty confident in just ordering the aforementioned kit but their return policy sucks (can't return and refund if packaging has been opened, etc). Cheers guys! Jason. -
Heater problems
My Toyota Celica SX blows cold air at the driver’s side when the heater is on, and it is an absolute nuisance. I get that it takes a while for the heater to work properly, but some reason after I have the heater on, it starts blowing out cold air even after a good warm up! I feel like the heater core may need replacing or the air conditioner/heater needs re-gassing. -
Entertainment Unit Upgrade
Hi everyone. Just after some advice on head unit upgrade. I'm looking to upgrade the functionality of the entertainment system to do a few things - display my dual camera from my caravan, utilise the HEMA OnRoad/OffRoad module, stream to the rear screens, and include wireless apple play. I've narrowed down to the most popular which seems to be Advanced Ice, EC Offroad and Galios - but none seem to do all four functions seamlessly. Not sure if I'm actually looking for a unicorn or not...has anyone had any experience in installing one of these systems and has it done all the functions? Any regrets? Cheers Mark
