The wife's twin-turbo boost-barge JZZ30
Hiro
ok next time i'll drift into him so he can get some fully hektik green stripes on the doors :P
How will you drift? Maccas trays?
New front rotors arrived on the doorstop the other day, just waiting on pads to go with them (and hopefully do the install this weekend) and the old girl will be back cruising like a champ
And to go with those shiny rotors, a nice chaser of Redstuffs
Got installed on Wednesday (attempted myself but was worried about rounding off the caliper bolts so left it to someone with better tools), has made an immediate world of difference - no more juddering when tapping the brakes at speed, no more slow pulsing to a halt at traffic lights ending up 2m from the car in front because of the sticking slides and warped rotors. Just got to get used to the significantly greater stopping power, only takes a gentle prod of the pedal to stop on a dime.
Hitting ABS in the dry might just be a possibility now, even with the KU39s...
  • 4 months later...
Well, the old girl got a tummy-tuck today....after many moons of scraping and scratching, we finally got the intermediate pipe remade and the exhaust raised up enough to no longer fear speed-bumps, driveways, seams in the concrete and the curvature of the earth.
Big thanks to Premier Exhaust, who did what others said couldn't be done, and at a decent price too.
Went out to get dinner the other night and I noticed that the headlights weren't turning on - parkers/indicators/fogs/tail-lights all worked fine, but lows and highs were completely unresponsive (and the dash indicator didn't come on for high-beam either). Wife then proceded to tell me that the headlights started cutting out intermittently on her a few nights previously (nice to be informed of these things...) before dying completely. Checked the headlight fuses today just in case and they were fine, next thought was the combi-switch but the dash still dims when you turn the lights on, the auto-headlight relay still clicks when you cover the sensor, and obviously the parkers are still working.
Done a bit of reading and it seems to be either the headlight relay or the integration relay - apparently the integration relay is a real pain to change and I don't seem to be suffering any other symptons (door jamb lights, key-ring light and dome-lights are all fully functional), so my hopes are on the main headlight relay in the engine bay. Would this be a special relay or can I just go down to Supercheap/Repco and use any 4-pin relay off the shelf (never had to play around with anything more complicated than wires and fuses)?
So the saga continues - got the driver's side wheel arch wiring repaired yesterday, headlights are now a go (although the driver's low beam seemed to cut out again last night, quick check this afternoon turned out to just be a loose plug on the back of the bulb). Unfortunately, the dreaded bong has now appeared in conjunction with the catalytic converter light and the "Alternator not charging battery" katakana. Pulled out the Power FC hand controller and monitored battery voltages on the way to work this morning, whilst driving they were sitting steady at around ~13.8-14V, with the ignition off but the key in the ON position it was around 12V, but dropped to 10V briefly when starting (and starting has been difficult on the odd occasion lately). Thinking it might be new battery time but the fact that the "alternator not charging" warning has come on every time the ignition has been turned ON as long as we've had the car (but would go away on starting) makes me think it could be alternator as we've changed the battery in the past (when it died) and the warning didn't go away.....sigh
Only 20-odd years after people started importing '90s JDM cars into Australia, the RTA has finally released a number plate which can fit into the rear bumper without being bent/cut/shaved, albeit American (12"x6") rather than Japanese (13"x6.5") size.
Ordered these less than 2 weeks after they first became available, when Cara went to pick them up the lady at the RTA said they were only the second pair she had scene in all of Newcastle. I expect to see them get more common as people realise that they are available, but for now they get a lot of attention.
  • 11 months later...
Sadly all good things must come to an end, and a combination of a cracked subframe/broken chassis and lack of funds the old girl has now passed on to the other side, on the way donating many of her more desirable organs to eager enthusiasts.
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    4. 199
      Advice Please
      A Greenskin
      Car Detailing Recommendations
      Landcruiser 200 GPS
    9. 11
      300 series turbo issues
