The coolant by-pass will not solves it. Recently I got that idle problems because I did not let it warm up as usual, it was a bloody cold morning it was. Warming up the car judging from the dissapearing of the intake hissing does the job for me.
Ditto that... i've had the same problem recently!
Spoke to a friend at work, his pre-facelift Ascent has the same problem, that means the Japanese & South Africa build cars have the same common problem.
dunno about the noise myself but it sounds like what was going on with rolagrls stivo having the wrong ecu fitted or somthing. but toyota replaced her motor because of it.anyway maybe you guys should contact her and find out the full details from her and see if its the same issue. if so you can all go back to toyota and get it fixed being they finally came to the party and fixed hers.
Could have been the car rejecting all the bright blue bits all over it....
    2. 0
    3. 9
      Android auto
    4. 9
      Android auto
    5. 1
      Turboed Corolla Overbuilt?
    6. 3
    7. 3
    9. 18
