Loud squeak noise coming from cluster when I rev
Keanu Da Palma
Hey guys I have a loud squeak/rattle noise that starts as I hit about 2000rpm and gets louder as the revs go up. The noise will only happen when I am accelerating and it completely goes away when I back off. It sounds like it's coming from the cluster but I'm not exactly sure. Need help asap because it is driving me nuts.
Mechanical speedo cable making the noise maybe? The cluster should be fairly simple to remove, with it out of the car see if the noise is still happening or not.
Or is it more like a static noise you can get in speakers?
I don't think that you can really lubricate the cable so you might be better off getting it replaced if that is what it is.
Have you removed the cluster to eliminate that?
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
