[Post Removed]
Spec_black you still have that big balled wolf as your avatar? lol
Blitz would be awesome. Heard a lot of good reports from the celica boys in the Cali area in the US. Very reliable. Many of them are daily drivers, one has had a blitz s/c installed with decomp. head gasket, diff. ratio pistons and he has no problems for 40,000k's and it's still going. 150 odd kw to the fronts and it runs a 1/4 in the late 13's early 14's.
You're getting a brake upgrade man...may as well do the motor now haha.
nice mate
keep us informed:)
im highly interested in how you are going to work the suspension and what clutch setup you will be pursuing:)
i know for sure that RDA make both front and rears cause i have a set on my car, were around $170 each last time i checked, also would be nice to be able to find a bolt on caliper upgrade option too....
Stage 1: Complete Brake Upgrade.
Can I ask what difference it makes to the stopping distance etc?
I play on the track a little, and have found that dropping from ~200kms to 60(end of striaght into hairpin) a few times, the brakes tend to soften a little, and it looked like the pads were getting a bit hot, so swapped them for TRD blue, which are good, but still after 6 or so laps they're softening, the liquid is already rated to ~800C which should be plenty, and fluid temp 'only' seems to be getting to ~400 :o , so I'm guessing it is probably the disks getting a bit too hot.
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    6. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
