2019 RAV4 oil filter wrench
Fenix radiator KUN26???
I have used Fenix in the past and had no issues with their products (French company I believe) -
Has anyone ever used this brand for a replacement radiator? Looking at changing my radiator as I broke the overflow outlet and want something more robust……. -
Pistons for 69 Corona
give these guys a buzz or browse through their website , @ Central Coast NSW Truck Parts and All Filters Hino Isuzu Fuso Mitsubishi Mazda Nissan Ud Toyota Dyna Delta (brettstruck.com.au) Or Gem Engines Good products Diesel Engine Rebuild & Reconditioning Sydney And Melbourne (hmgem.com.au) -
My dad is rebuilding the engine of a 1969 Corona and is struggling to source pistons for it. Does anyone know of a supplier? It is a late model 2R with 1490 cc. engine capacity. The engine Bore is 78mm (3.07") diameter. The piston size required is to be 0.040 thou bigger in diameter. Any ideas? Thanks in advance! -
LC200 Series GVM Upgrade
Hi looking for feedback on the ride quality of Lovells 3800kg and 4200kg GVM upgrade. Pros and cons of each. -
6
Are you an authorised repairer...if not then do so at your own risk. -
6
You can add Nulon to that list too. They make excellent products. Support local industry. Penrite and Nulon.- 1
6
Thanks @campbeam and @Tony Prodigy for the info. @bob007 As per T&C from TOYOTA, my car is still with warranty as long as it's serviced properly. https://www.toyota.com.au/-/media/toyota/main-site/page-data/warranty/files/toyota-warranty-advantage-terms-conditions.pdf In order to keep my warranty, I probably will have to keep all my receipts for parts and oils. The reason why I want to service my RAV4 - I know the dealership use VPS 10W-30 for oil change. Nothing wrong about the oil but I want to use better names, due to 12 months service interval of the latest models. I am looking to switch to 0W-16 or 20 from Penrite or Mobile1. I have been servicing my 2012 COROLLA for over 4 years and have no issue performing most of the work as per log book. -
AE82 2zz-ge and 6spd swap
I am researching the viability of swapping a 2zz-ge into an ae82, I have seen a few ae82's and 92's with the swap done but no detailed information on mounting, driveshafts and the shifter. Hoping someone has done the swap or seen one done and can give me an idea of what's involved. -
2022 Toyota Camry Hybrid Should I buy it.
Back in 2019...I did a lot of research on Petrol vs Hybrid that's why I bought a Petrol Camry. The Hybrid battery that sits across the back seat costs many thousands to replace...Toyota gives you a 5 year warranty...10 years it you service the car with Toyota. After that you pay...your car wont be worth much in 10 years. If the Hybrid battery dies...you can't jump start it. The Electric motor that runs the system also costs heaps to replace...replacing the brakes cost thousands to replace...Hybrids cost thousands more to buy. Toyota says you only use 4.6 lts per 100 kms but you must use 95 octane or higher and there's the cost of the Hybrid battery replacement...so where's the saving.
