Individual Throttle Bodies..
To run it as they have in the pic you will need to ditch your MAF and run a MAP sensor, which means you will have to convert to a full aftermaket ECU because the PFC cannot run it....
The way to get around this to build a plenum and enclose the throttle boddies and this would enable you to keep the MAF.... Just like on the Silver top 4AGE 20V's.... Or like this guy has done on his turbo 1zz http://www.cardomain.com/ride/242344
But then you will loose all your Blingy rice factor.... for the expense that would have to be outlaid and the minimal gains you would see ... it is not worth it
Here is a link to a thread about this car/ITB setup from newcelica.org from march...
http://www.newcelica.org/forums/showthread.php?t=206895
on newcelica forum, it mentined that 4A-GE ITB lined up pretty well for 2zz-ge, but its runners are too small. Now that ITB looks to be a modified 4A-GE - and someone mentioned that too on the post over the newcelica forum.
    2. 54
      Stout Owners
      New Member
    5. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    8. 199
    9. 1
      Advice Please
