Aurion oil leak woes
the drake
Hi Guys,
Had a major oil leak last Friday, basically I just got onto the freeway and the low engine oil pressure light came up on the dash. Pulled up immediately on the breakdown lane, and looked underneath the car. There was a leak evident, and looks like the leak occurred at speed as there was a fair bit spread underneath the car and splatter near the rear diffiuser.
Anyways, I got the car towed to my local dealership, and just today they have found the oil leak - a pinhole leak on a oil pipe. I queried whether this was a VVTi Oil Pipe as i'm aware of the issue of VVTi recall and updated pipe available, however they have said it is a different oil pipe. I do recall when purchasing the car second hand the dealer told me the VVTi updated pipe replacement has been carried out. Furthermore, when I checked underneath the bonnet there was no smoke, or burning oil smell (which I would expect if it was VVTi hose close to the engine)
- They want to charge me $140 for the oil pipe, and 1.5hrs worth of labour for the install. WORST thing is the pipe is not available in the country, and I have to wait 14 working days for them to bring it in! Does this sound right?
- I also asked them about carrying out 120,000km service after the repair (as it has already done 117,000km already) and they wanted to charge me $490 for the service. Most dealers I called were charging $345. They lady said it was because of the brake fluid replacement, though this fluid is only 500ml, and is less than $20 at Supercheap. The reason why I want to do this service as they will need to top up the oil as most has leaked away. I think they're trying to stitch me up big time. Thoughts?
- Lastly, will there be any issues with storing the vehicle whilst waiting for parts (14 working days..), with little or no engine oil? With summer well on its way, I have some concerns...
Any thoughts/advice/recommendations or insights highly appreciated.
TheDrake
Edited by the drake
TheDrake
Parts often as not are not in stock and a 14 day turnaround for a not-in-the-country part is quite good. Every part that I've ordered that has had to come from OS has been 6 weeks.
Brake fluid replacement (often referred to as a flush) requires the removal of the old fluid and replacing the new fluid which isn't as simple as topping up the reservoir with new brake fluid. A brake fluid flush is important so you really shouldn't skip it.
http://www.gadgetonline.com/BrakeFlush.htm
      How much is a Toyota hilux grinner 1990 2xd worth
    2. 8
      1998 Toyota Celica Pricing idea
    3. 1
    4. 4
      Has anyone found 200 Series Rear Screen Delete Cover in AUS
    6. 11
    7. 1
      2007 - floor mats
    8. 1
      2002 Hilux Engine Replacement
    10. 3
      Engine conversion
