i apologise if this has been asked and answered in the past but how many pre-out's does this unit have and is there a separate Sub out?
Which unit are you referring to? The Auspack unit?
If so, the Auspack unit has a single stereo RCA out. There is no dedicated subwoofer output.
I am trying to buy the reverse camera for my Aurion ZR6 2008. The camera came with the unit I could fit into the original hole and blown up. Would you have pitchers of reverse camera, fitted in the original plastic cover plate? If possible you could give me eBay seller details. Thanks
Watch out with the photo quoting there :P
Anyways, a camera that seems to be a good fit would be the one specified in the thread here:
Toyota Aurion Reversing Camera Installation
I received my reversing camera today. And I wired it up as suggested previously. My head units all other functions work fine. My camera works but I have to go in to main menu to select the camera mode to see it. I want it to make it turn on automatically when I shift in to reversing gear.
I connected the Reverse (pink) wire as you suggested, to red with white dots. It makes the camera mode stay on.
My parking wire does not have a loose end to connect to earth. I do have loose wire called ILL – PWM and I trying connecting to earth. Doing this makes the camera stay on and I cannot get into any other mode. I left the P.Center and Mute loose. Any suggestion.
If connecting to the wire specified in my guide does not activate your reverse camera only when reverse is selected, then here are my next two suggestions.
1) Use a multimeter and test for any wires around the passenger side kick panel that are +12v when reverse is selected. Then you can tap into that one.
2) Extend the wires and connect directly to the reverse light itself. That will be guaranteed to work.
Thanks DJ for quick reply and I will try this.
Finely I found the wire to connect my reverse Pink wire. DJ as you suggested previously finding a wire using multimeter. That was a read wire in the left kick panel and 2nd block from the bottom, red wire is on the top raw of the plug. Now when I am playing radio AF sign is flashing in the bottom left corner of the screen (only in radio mode). Does anyone know what this means. Thanks again guys.
  • 7 months later...
Be wary of am email sent out to previous Dig_Options unit purchasers prompting to check out a "supplier" that has a GPS software update for the units.
The software is pirated.
If you aren't going to support the makers of the software then at the very least don't pay people for something available for pirate download
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
